Does it matter if you hook up the hot and neutral reversed on a solid state ballast? Would it effect life of an LED lampV
the issue was with LED track heads. there was no clear way they fit in the track. one of the guys running the job said that if we put them in backwards it would shorten the life of the LED.
So they don't like 240v?The more common 120 to 277v ... ballasts are not designed to have the white lead more than a few volts over the ground/case and you may compromise reliability.
