Re: Solidly grounded systems
Good drawing ED. Low voltage systems are are frequently operated solidly grounded. Reason being are the line-to-neutral loads common in these systems. For low-voltage systems without L-N loads, solid or high resistance grounding are the practical choices. Low resistance grounding is usually not considered since it would require the use of sensitive protective relaying (expensive) throughout the system.
High resistance grounding can be used for alarm only applications where service continuity is of prime concern, and if the fault circuit can be located and isolated with little delay
