Trying to understand this statement from an article I'm reading, "Solid grounding facilitates the automatic clearing of ground faults by circuit protective equipment (fuses and circuit breakers) because solid grounding results in the highest magnitude of ground fault current".
I thought solidly grounding refers to connecting the neutral of a system directly to ground without any resistance in between this connection. How does this assist in clearing faults quickly??? I thought bonding does that.
