hhelectric@bizec.rr.com
we are woking on a pool that was not bonded properly...we have a 1.8 volt difference between the water and the decking perimeter surface..any recomendations
If there is voltage with the power off, then you need to contact the power company as that is often the case. If the water lines are metallic and they are connected throughout the neighborhood it is possible that the current is coming in on the water lines from those homes.
