e57
- San Francisco, CA
Working on a spread sheet for doing load calcs so the PM's can get some easy input/output on service sizing when bidding. As often most of the equipment is not known up-front during budgeting it would not need to be exact, and require a disclaimer with it.... Since the company I work for does mostly custom residential - these homes are often far in excess of the code required min's for 3va/sq' - some often have AV equipment that dwarfs the KVA needed for a typical home in total, and lighting so over the top that if all the lights were on it would be closer to 30+va/sq' in lighting alone.
Anyone have any quick/easy 'factors' for the excessive loads of the rich and famous?
:grin:
