Alwayslearningelec
- NJ
- Estimator
Is it code to have sub panel or an ocpd at panel equipment pad? I know it makes more sense but I'm wondering about code right now Thank you for help
Someone told me it was code to have that? If so that means I can't run a 20A circuit from my inside house panel DIRECTLY to the pump and another circuit DIRECTLY to the GFI and gas heater? If I need an OCPD what could I use for a 20A circuit? No disconnects that size.Helps to makes your pump disconnects 50’ and within sight.
Is this pool in New Jersey? Are you working with an electrical contractor? Even if they're reluctant the local electrical inspector should be able to answer your questions.Someone told me it was code to have that? If so that means I can't run a 20A circuit from my inside house panel DIRECTLY to the pump and another circuit DIRECTLY to the GFI and gas heater? If I need an OCPD what could I use for a 20A circuit? No disconnects that size.
New York now...no inspection needed.Is this pool in New Jersey? Are you working with an electrical contractor? Even if they're reluctant the local electrical inspector should be able to answer your questions.
Oh your profile says NJ please update it when you have a minute. Thanks.New York now...no inspection needed.
