eMeasure
- San Francisco
Hello everyone,
This is Adam once again.
Firstly with a major break upon us I'd like to wish everyone a very happy festive season and an even better 2017.
I wanted to share some brief thoughts on what is involved with moving from something you do manually to something that is digital instead.
Regardless of what role this digital system is intended to play there is some good housekeeping you can follow to ensure you consider all your options.
A digital or paperless solution means no paper handling and easier file storage and retrieval, and working electronically makes it easier to keep up to date with the latest issues. An accurate digital system can dramatically reduce working time and allows you to work anywhere that you can take a laptop.
The next big consideration is cost. Cost is always important to take into consideration. Some systems can be expensive and require you to buy outright- making a huge dent in your budget. It can take a while to see any sort of ROI in these cases. Make sure you’re not spending money on features you don’t need! Higher cost doesn’t necessarily mean higher benefits for you if you won’t be using the features. Rental systems are always a bonus too- ensuring that you’re only going to have to use it when you need it! A slow month means no payments and more in your pocket.
So what’s the best way to check what’s right for you? Simple- test it out. Most systems offer free trials, so if you’re serious about getting something that works for you, check out the free trial first- and of course, make sure you actually use it!
Something equally as important is to make sure you don’t get fooled by hidden costs. Some systems can charge you for new upgrades, support or training; all necessary to actually use the program. Make sure your system has comprehensive training materials available and that you’re aware of the potential costs.
If you've read this far then I thank you and once again wish you a very happy festive season.
Here is to 2017
Here is to 2017
