VII. Hydromassage Bathtubs Hydromassage bathtubs as defined in 680.2 shall comply with Part VII of this article. They shall not be required to comply with other parts of this article.
680.71 Protection.
Hydromassage bathtubs and their associated electrical components shall be protected by a ground-fault circuit interrupter. All 125-volt, single-phase receptacles not exceeding 30 amperes and located within 1.5 m (5 ft) measured horizontally of the inside walls of a hydromassage tub shall be protected by a ground-fault circuit interrupter(s).
I don't know. You'll have to get a definitive answer from somebody else here. Or, read between the lines on what's been posted so far.Originally posted by mitchell:
What is your interpretation of a switch? <snip>
