Disposal
Disposal
I have an LED control board that is listening for
momentary pulses of 110 VAc current.
The control board has a second source of 110v
going directly to an attached LED driver
Circuitboard is programmed to pass through the
24vdc from LED driver
Outputting different patterns of 24vdc
depending on the number of pulses received.
For example one pulse of more than two seconds
might give you dimming
release the contact and then reapply
the similar pulse more than two seconds
would give you brightness.
Three pulses might give you the top middle bottom strands
Being energized
four pulses might alternate through different patterns
six pulses might change the program.
The circuitboard is looking for pulses and modulates
the output of the independent LED driver.
depending on the quantity and duration of
the momentary control voltage pulses
When the control board receives a pulse
That has a corresponding program
it
Sends the
outputs from the driver to attached LED Strands
These LED strands then produce various types Of
twinkles and shimmies
Believe that’s the correct technical term
It doesn’t really matter
https://vimeo.com/226425194
because my question was much simpler
and that is I believe
Somebody has installed a
2p momentary contact switch w center off
When
a disposal switch.
Would make signaling for the untrained user
much simpler
I just didn’t know there was a simple disposal switch
Avail which was specified but not installed
Thanks for your help.
