Is the switch used as a control, disconnecting means or both? There are higher capacity snap switches available, you could also use a circuit breaker, molded case switch, fused or non fused disconnect as combination control and disconnect, or use a light duty switch and contactor for control purposes - you likely still would need a disconnecting means in almost all cases.
Another possibility:
GFCI protect feeder to a small panel and feed all pool related equipment from this panel with non GFCI breakers. You only purchase one GFCI, however troubleshooting the tripping GFCI gets a little harder because one faulty component makes everything shut down.
Have you ever noticed that customers can afford pools and spas but can't afford to hook them up? And are willing to risk their lives by having their friend or relative who is 'good with tools' hook it up for a beer and opportunity to use the pool or spa.
Spend a little more on a good install now or spend more on trouble calls later.
