Can you hook up a 110v spa that basically has an extension cord wired to run it, and not a GFCI packaged unit to an office out building 21ft away. If I change the exterior outlet to a GFCI and run RMC 6" under to a 4X4 post with rain tight outlet cover. The extension cord is on the other side so I would have to run it around the spa to the outlet. Lets say the outlet is 5 plus feet away, ran in 12/2 w/gnd. Can I use romax or do I need to use UF cable. Also the breaker is not dedicated and runs an added on office. This is for Residential.
