bigwilleus
- North Carolina
- Industrial Electrician
I'm looking to add a concrete patio off the back of my house where my meter base is located. In doing this my #8 bare wire going to my ground rod will then be encased in rebar reinforced concrete. The patio slab will also extend over past my house and up to a retainer wall that is about 2' higher than the patio slab where there is another rebar reinforced slab for vehicle parking. On the patio slab I'm planning to put a hot tub that will be about 2' from the parking area retainer wall. Does this hot tub now need the equipotential bonding around it being it is with in the 30" to the parking area slab? The concrete slab for the parking isn't technically a metal object but it is definitely current carrying. If i put the equipotential bond for the hot tub, then it will be bonded to the grounding electrode via the rebar reinforced concrete patio slab. Any thoughts on this.
