Re: Spa installations
I doubt the sauna lamp was negatively impacted by the heat of the sauna.
The filament of an incandescent lamp is simply a resistor. If electrical power is applied, it is converted to heat in the filament. The filament's temperature rises until it gets rid of heat at the same rate that heat is being generated in the filament. Ideally, the filament gets rid of heat only by radiating it away, although a small amount of heat energy is also removed from the filament by thermal conduction.
The filament's temperature is very high, generally over 2000 degrees Celsius, or generally over 3600 degrees Fahrenheit. In a "standard" 75 or 100 watt 120 volt bulb, the filament temperature is roughly 2550 degrees Celsius, or roughly 4600 degrees Fahrenheit. At high temperatures like this, the thermal radiation from the filament includes a significant amount of visible light.
