Freshta
 - Raleigh, NC
Hey guys,
New to spa installation and want to run this by you to see if I'm reading the code correctly....Situation: Was once a spa at customers house but wiring is undersized (8-3). GFCI breaker is located at main panel in garage. Disconnect is mounted at corner of house but needs to be replaced because it is damaged.
My intentions: I plan on using the existing 50 amp GFCI breaker located in garage. I will run 6-3 w/ground NM-B in crawl space to a new pull out type disconnect located at back of house (50' run). From the disconnect I will run 6-3 w/ground UF-B inside of 1" PVC in 18" deep trench. From disconnect to proposed spa location is roughly 30 feet. The spa will be placed on top of a wood deck being built for it. The owner doesn't know what brand or exactly where spa will sit exactly, so I'm leaving extra UF cable hanging until placed. How does this sound?
Once placed, will I need to run the UF inside of flex, or will it be code to run it directly to the control panel?
Thanks....
Tony
Thanks....
Tony
