First and foremost, Section 680.42, 2008NEC requires perimeter bonding. The spa sits on a concrete slab poured with no provisions for bonding to spa. How can this perimeter be bonded?
Section 680.42, 2008NEC requires flexible conduit in length of no more than 6 feet as wiring method to supply spa control panel. The length in use now run under the deck from the outside wall disconnect to pool panel located inside the plastic skirt of the spa is longer than that. How can a raceway other than flex be correctly supported from disconnect to spa panel?
Would the metal fencing resting on the ground and surrounding the spa to keep dogs away need to be bonded?
Thanks
