Re: space heater for induction motor
If you have condensation heaters, I suggest they be wired thru the motor started on a set of NC contacts. When the motor is running the condensation heaters are turned off, the motor does not need the extra heat when it is on. Also be sure you comply with 430 part VI on more than one source of supply to a controller, I use an aux contact on the motor controller disconnect switch to turn off the 120V circuit. AB makes a motor condensation heater that is fed from the motor controller ckt, it runs a low power tru the windings when the motor is off. This allows a motor winding heater if it can't be field installed.
