spaceheaters
bartman42
if i have 3 fixed space heaters on one feeder, one is19.2kva and the other two are each 1kva all at 240 volts single phase , how do you calculate the minimum demand
Re: spaceheaters
Try 220.15( Stand. Cal.), 220.30(C5)
( Optional) or 220.31(B)(Opt. Add.), 424.22 OCP
Maybe this will help!
[ August 29, 2003, 07:49 AM: Message edited by: tr ]
Re: spaceheaters
19.2KVA + 1KVA + 1KVA = 21.2 KVA.
(21.2) x (1000 VA) / (240 Volts) = 88.3 amps.
With the information you provided, there is no applicable demand factor that would allow you to reduce this value.
