Spade Terminal Connector Options
duttonbrown
Lighting Designer
Minneapolis, MN, USA
Product Engineer, Lighting Designer
Hi guys,
Wanted you all to know my business recently became UL registered thanks to help from this forum. So thank you all!
I have a question. I'm looking for the best way to split one 18 gauge wire into two 18 guage wires. Are there splice connectors that can be used to crimp one 18 gauge wire on one side and crimp two 18 gauge wires on the other side? If not, is there a spade or ring terminal connector with a crimp hole rated to accommodate two 18 gauge wires?
I know I could get a larger spade terminal connector rated for 10-12 gauge wire, but none of those are rated to be crimped onto two 18 gauge wires. If not any of these, is soldering my only option?
Thank you so much for your help!
Thomas
There are these:
I buy them from McMaster Carr when I need them. They allow you to connect 3 wires together.
Must it be crimp type?
