speedypetey
- Hudson Valley, NY
I would like some comment and opinion. I am having a bit of a battle of wits over this topic.
In the opinion of the professionals on this site, is 680.23(F) applicable to the main feed to an outdoor package spa if the spa has a light factory installed?
We have all seen these spas. The little low voltage light with an open socket with two free leads going to the control panel of the spa.
"680.23 Underwater Luminaires (Lighting Fixtures)
(F) Branch-Circuit Wiring
(1) Wiring Methods Branch-circuit wiring on the supply side of enclosures and junction boxes connected to conduits run to wet-niche and no-niche luminaires (fixtures), and the field wiring compartments of dry-niche luminaires (fixtures), shall be installed using rigid metal conduit, intermediate metal conduit, liquidtight flexible nonmetallic conduit, or rigid nonmetallic conduit. Where installed on buildings, electrical metallic tubing shall be permitted, and where installed within buildings, electrical nonmetallic tubing, Type MC cable, or electrical metallic tubing shall be permitted."
"Wiring Methods Branch-circuit wiring on the supply side of enclosures and junction boxes connected to conduits run to wet-niche and no-niche luminaires (fixtures),"
There is no conduit running from the fixture so how can this apply? Besides, these are neither wet niche nor no-niche according to code definitions.
" and the field wiring compartments of dry-niche luminaires (fixtures)"
These are NOT dry niche fixtures, so how can this apply?
It is my contention that none of the parameters in 680.23 & 680.24 are applicable to the type of lights in these spas. Also that these spas are factory built and listed. The light has a feed and control built in. The sections referred to are targeting lights installed in pools.
The person I am disagreeing with says if it has a light, at all, 680.23(F) must apply and the complete circuit to the whole spa must be run in conduit back to the panel(1999/2002 NEC, not 2005 which allows MC).
Any takers???
Any takers???
