Rose - Service transfigurations are: 120/240 three phase Delta 120/208 three phase wye 277/480 three phase wye and the last one I am going to name is rarely used but its called a three phase open delta, they only use it when absolutely necessary because the transformer can only be loaded to 60% (sometimes its used for a few homes) then you also have single phase 120/240 which is just two phases from a three phase delta. I'm not a lineman but we had a maintain contract for an airfield. Are you in the USA ? The counter man should be able to help you. If you just need a lightning surge protector its pretty basic, one side is connected to ground and all two or three phases connect to terminals 1-2-3 and all that's between ground and the phases is a very small air gap allowing the lightning to "track" or "jump" across it to ground thus redirection saves expensive items in a building. Now a surge protector is more involved, I call it a clipper because it only allows it to get to a pre determined level and then drains it off. The power company usually has them on their poles as well. 1
