The problem is with a speaker thats tied into a smart board set up when we plug the speaker into the 110v outlet there is a loud humming if I disconnect the connector from the computer [ie the speaker input ] the hum stops.
also if we feed the speaker from a different outlet there is no hum at all
and yes I checked all the grounds and replaced all cables the run between the smart board and the computer Thanks Matt
