Re: Speaking of colors...
The problem is that as an inspector, I can't pick or choose what or what not to enforce, even if it is in favor of the contractor. This is especially true if it stems from a personal belief. I too agree that logic and common sense is all that is needed for this situation, but the code is code. I happen to think most grounding requirements are a big waste of time, however I have to enforce what is written. Don't I?
A while back, I questioned if it would be wrong to not allow FMC in wet locations because I didn't feel installations could ever meet the provisions of the section that permitted FMC outdoors. Many responses where in the order of "don't inspect based on your opinions" or "if you don't like the code, submit a proposal and get rid of the allowance the proper way".
Doesn't this work both ways as Roger has alluded to? So bascially, no matter how insignificant a code requirement may be, shouldn't the inspector enforce it with no bias?
