jjhoward
- Northern NJ
- Owner TJ Electric
Is there a special expansion joint that can be used with 3" PVC directly below the meter pan?
I thought I had seen this in a CE class I took last year.
It wasn't a standard thermal xpansion joint mounted vertically, it was specifically for absorbing ground shifts and the 90 degree sweep was part of the assembly.
Am I dreaming this stuff up or does this exist???
Thank you.
Thank you.
