https://www.ecmweb.com/qa/code-qa-protection-options-type-nm-cable apparently covers the extent of what the NEC says about this topic, but in jobsite reality, it appears this omits any specifics as to where wire-protection plates (https://www.lowes.com/pd/STEEL-CITY-2-1-2-in-x-1-1-2-in-Gauge-Nail-Plates-100-Pack/3422476) are required. In typical wood-frame construction for Hawaii, where insulation in walls is rare, 2x4 studs are the norm. So a run of NM-B through studs will be "protected" behind (3.5"/2=) 1-3/4" of lumber, minus half the hole diameter, plus the thickness of the wall sheathing - or about 1.5" of wood/gyp, minimum. Is that considered adequate depth by NEC? or is this a judgement call?
The plates are cheap and would be relatively easy to install, even everywhere a wire passes through a stud, but I'd rather not worry about bulges in sheathing material in otherwise-flat wall surfaces, which can jump out from certain lighting conditions.
