Hope this is not too much of a "how to" question:
I need to spec conductors for a project. I can gather info from the ME's and CE's about environments, spaces and do the calcs needed to determine ampacity required for the various loads and run lengths.
Chapter 3 of the NEC provides wiring methods. In some cases it provides detailed info on certain cable types (UF MC AX or what ever) and how they can be used and not used. In other cases, there are cable types that are only listed in Tables. Ex THWN-2 = wet and dry locations.
Does the fact that a cable such as THWN-2 is not explicitly described in a separate article mean it can be used in accordance with a table, any wet or dry location, not otherwise prohibited by the code?
