gar
- Ann Arbor, Michigan
- EE
170412-1131 EDT
Shaneyj:
You are an EE student. This means that you should have resources, lab equipment and professors, that could help you on your problem.
What is a universal motor? This usually means a motor with a field winding designed and used in series with a commutated rotor winding. You might initially consider this a DC motor. But if you study what is occurring internally you will see why it will run on AC.
Looking at the motor terminals this device has an AC impedance. But it also has an internal voltage generator. The current thru the motor is a function of speed, mechanical load, and the series impedance. Mechanical load is made up of internal frictional and windage losses plus the external load.
In a DC type motor speed is determined by field intensity, applied source voltage, internal IR voltage drop, and counter EMF (the internally generated voltage). If a DC shunt motor looses it field excitation, then the motor RPM is likely to runaway with destruction of the motor because with less field the motor has to run faster to produce the necessary counter EMF.
In a universal motor the field is proportional to motor current. Because of internal motor losses and windage an unloaded motor current increases as speed increases. Thus, field intensity increases with speed and the motor self limits speed.
For a fixed source voltage speed decreases as load increases because of two factors --- field increases because of load current, and internal IR causes a reduced need for counter EMF.
Shaneyj:
