It may of been done using a hickey, trial and error, or if the radius was constant, a roller jig could of been used
Screwing it together must have been a real bear!(I saw an example in a old lighthouse. It was done in rigid conduit and used for light fixtures for lighting the stairs.)
Stainless hydraulic tubing and butt weld. Standard 20ft lengths in inch sizes, 6 meter in metric sizes.Screwing it together must have been a real bear!![]()
(I saw an example in an old lighthouse. It was done in rigid conduit and used for light fixtures for lighting the stairs.)
That's why they have compression fittings.Screwing it together must have been a real bear!![]()
FWIW, 360 degrees of bend along the helix will end up at more than 360 degrees as seen looking down the helix's central axis. If you think of a tightly coiled helix (i.e. basically a circle), pulling the coils apart while keeping the curve confined to the surface of a cylinder has the effect of straightening the pipe, so there is somewhat less bend.Don't forget pull boxes or condulet "C"s every 360 deg.
If an inspector calls you out on that, he better know how to figure it out as well is all I am going to say.FWIW, 360 degrees of bend along the helix will end up at more than 360 degrees as seen looking down the helix's central axis. If you think of a tightly coiled helix (i.e. basically a circle), pulling the coils apart while keeping the curve confined to the surface of a cylinder has the effect of straightening the pipe, so there is somewhat less bend.
Cheers, Wayne
Maybe I wasn't clear--the effect is that mathematically you can space the pull points farther apart on the helix that one would think at first glance. So if you choose to take advantage of that, the inspector might reasonably expect you to explain why that is.If an inspector calls you out on that, he better know how to figure it out as well is all I am going to say.![]()
I did misunderstand and thought one might need the pull points more often than you might normally expect. Maybe learned something today even if I will never use it.Maybe I wasn't clear--the effect is that mathematically you can space the pull points farther apart on the helix that one would think at first glance. So if you choose to take advantage of that, the inspector might reasonably expect you to explain why that is.
I haven't actually figured out the exact magnitude of the effect yet (it will depend on the ratio of helix radius R to the spread between coils), so my comment was primarily academic.
Cheers, Wayne
I see what you're saying. It would seem logical that, as viewed from above, the C-condulets would be stacked in a straight column.Maybe I wasn't clear--the effect is that mathematically you can space the pull points farther apart on the helix that one would think at first glance.
