LarryFine
- Henrico County, VA
- Electrical Contractor
Title basically outlines the question: meter outside, 200a MB panel inside.
Is it permissible to remove bottom incoming conductors from main breaker, splice on new conductors in panel to reach ATS above panel, return on new conductors to main breaker.
I imagine the neutrals and grounds must be separated since the ATS will now be the main disconnect, so I'll need SE up and SER down, unless there's a way to avoid having to do this.
