solarken
NABCEP PVIP
- Hudson, OH, USA
- Solar Design and Installation Professional
I need to extend some 4/0 line conductors and 2/0 neutral of an underground feeder about 6 feet. The conductors currently terminate on feed thru lugs of a meter-main outside, I will probably cut the conduit, pull the conductors out the bottom, and pull thru the wall inside to a junction box, and extend from there. Should I use a mechanical splice and heat shrink like this, or should I consider something else?
