When is the last time a wirenut kicked your butt?"No need for expensive and frustrating wire nuts."
Originally posted by celtic:
When is the last time a wirenut kicked your butt?![]()
I don't have the code book. So, is it allowed? How about splices other than wirenuts, like, soldered or butt crimp splicers? I'm replacing an old 100 amp fuse panel with a new 200 amp breaker panel in St. Paul, MN and some of the old wires are too short to reach the terminals.Originally posted by davewelec:
Is it permissible to have wirenut splices in a panelboard or loadcenter. I've heard many say that it is not but can't back it up with a code reference.
I went down to Mexico on the 4th of July to visit family and boy I tell you what some of the ways these guys wire things will leave you speechless, one example: three house running off a 60 amp service, one is fed with an extension cord I found that most houses are 60 amp or 30 amp. And you should see the tie in at the utility pole, wires wrapped around the utility wires no crimp on connectorsBy petersonra: I liked the tied connections the Mexcian electricians used. No wire nuts. Just knot the wires together and tape over it. I was skeptical at first, but I tested a few of them and they are tighter and more secure than a typical wire nut connection. Not good for solid of course, but very effective on small, stranded wire connections.
