peterpaulw
- Philippines
- Electrician
Is twisting multiple wires together and then taping them with electrical tape a splice permitted by the NEC? - This is not an April fools joke. The country I live in uses the NEC 2017 copied verbatim into the Philippine Electrical Code (PEC 2017). The NEC/PEC 110.14(B) states: "Splices. Conductors shall be spliced or joined with splicing devices identified for the use ... " (and I am not asking about soldered connections). - I am asking about connections made by twisting wires together (without wire-nuts) which I see all the time in most residential and business installations, usually inside PVC junction boxes and sometimes right on wooden beams. Commonly between 2 and 5 stranded or solid copper wires of AWG 14 to AWG 10 are twisted together with lineman's pliers carrying up to 30A of 240V current. Recently an electrician came to our house from the local POCO. He made multiple new live-wire twist-and-tape connections to repair and reconnect the insulated aluminum wires that go across the street feeding our meter on a 100 ampere residential mains connection. We still have power - for now
They all act as if this is permitted by 110.14(B). What is puzzling to me, is that experienced Philippine electricians continue to teach this method today (in numerous videos) and leading Philippine electrical engineers who are familiar with the code do not even mention it as a potential risk. Proper "splicing devices identified for the use" such as UL listed wire-nuts are actually available, but are not used widely. Therefore, I am wondering, if I may have misunderstood the code? Where does the code explicitly forbid such splices? Could NEC/PEC 110.14(B) or another part of the code actually be interpreted as endorsing "twist-and-tape"?
On a practical level, what are the disadvantages and risks of using twist-and-tape as the primary method of wire splicing? Often I encounter splices made with cheap Chinese electrical tape which start to unravel after only a short time, whereas splices taped with higher quality tape such as 3M electrical tape tend to look much better even many years later. In my observations here during the past 30 years, these connections can actually hold up quite well, if the initial mechanical connection created by the twisting of the wires was done by an experienced electrician, but at other times I come across splices which are barely held together by the minimal pressure of the electrical tape.
Having answers to these questions would really help to explain to local electricians we hire, why we want them to use wire-nuts instead of twist-and-tape.
The last two photos are from a recent video about wiring an outlet by an electrician whose popular channel has 7 million views
