whisperinghill
We have an existing 225A 120/208v 3ph 4w panel that is to be relocated. The existing feeder leaves the distribution panel and passes thru a junction box, (no connections, splices or taps) and to the panel.
Can I move the panel and then run new wire to the j/box and assuming there is sufficient room, splice the wires with either a terminal board or other splices? Purpose would be to now have to shut down the distribution board to run new feeders to the existing breaker, critical computer systems connected.
If its ok, can someone point me to the applicable NEC code?
Thanks
Thanks
