I have some existing multiwire branch circuits that are feed from a critical panel in a hospital. The circuits feed lights and receptacles. I would like to move some of the circuits to a new panel on a different transfer switch (per 517.19(A)exception #2).
Can I simply splice a wire to the existing neutral wire and tie it to the new panel neutral bus?? So I would have a neutral coming from each panel, they would be spliced together and run as a single wire, then they would split into two wires and go to separate receptacles along with the hot wires.
Hard to explain...does it sound legal??
Steve
[ June 29, 2005, 03:41 PM: Message edited by: steve66 ]
Steve
