Bill1974
- Hauppauge, NY
I have an application that requires splicing two large wires and one small one and can not find much on how this should be done correctly.
I have devised that require to 10 gauge wires and a 20 gauge wire to be splices and have have found one wire nut that is rated to join these together. I assume there are more out there but I can not seem to locate them.
The other two cases I have are joining two 6 gauge with a 20 gauge and two 2 gauge with a 20 gauge.
The 20 ga wire isn't load carrying it's for a voltage sensor.
Anyone help with some appropriate hardware to splice these combinations? is the only option to splice a larger wire onto the 20 gauge and than splice to the 6 gauge or 2 gauge wires?
Thanks
Thanks
