Splicing grounds
Alabama
Contractor
So I have a GE powermark plus load center, the neutrals are double tapped with most of the grounds on the left bus bar. Is there any code against splicing the grounds and running them to the right bus bar? I would appreciate any information. Thanks
Welcome to the forum. What type of contractor are you?
Make sure it's okay for the grounds and neutrals to share the same bus(es) in this instance.
You can splice several EGC's together and pigtail off to the bus. You cannot do the same with several neutrals.
I'm a General contractor. I've have plenty experience in electrical but im not as farmiliar with the NEC as most of the people on this forum😅. This instance IS the main service disconnect if that's what you're asking.
The forum rules do not allow us to assist those not in the electrical trades perform electrical work.
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
* This NEC� Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
