oldhickoryhomeinspections
- Tennessee
- Home Inspector
Hello, TN Licensed Home Inspector here.
We recently came across a 6/4 electric conductor routed through an attic space which was spliced at two different locations within two separate junction boxes. This conductor was servicing an electric sub panel at the rear of the house.
This seemed like an unusual amount of splicing on a large gauge conductor which we do not typically see, but we were unsure if this was a reportable issue. We noted the condition was "not typical, could be further evaluated".
My question is, are there any issues regarding splicing larger gauge conductors feeding sub panels which would result in a notable loss of power/ohms/amperage?
If these splices are acceptable, is there a maximum amount of splices which can be used on larger gauge conductors servicing sub panels?
Thank you,
Thank you,
