smarteng
- Los Angeles
Hello Guys,
Is is okay to splice one circuit into three parallel circuit. I have one 200 ft, 3 phase 4 wire run ( 750MCM in 4" conduit). I need to splice it at about 150 ft and continue into 3 parallel run (3 parallel 2/0 in 3 parallel 2" conduit) so that I can use smaller conduits due to crunch of available space. I am planning to splice inside a underground Vault. Is it okay to do. Do I run into any technical issue/short circuit issue/NEC code compliance issue. May you please advise.
Thank you
Thank you
