cashpoppper
- usa
- hvac
I did a small diy cheap job with some left over project materials. I wanted a duplex outlet split right next to the subpanel, so if I trip one with power tools I won't loose my lights. Seems like a decent idea?
I added an outlet circuit in a sub panel, I broke the tabs on both the hot and neutral sides, ran separate 12g neutrals and hots, a ground 12g, bonded the ground to the box. 20amp QOs.
The entire length of the circuit might be 14 inches at most from breaker to outlet. 3/4" with plastic bushings on the knockout size of choice.
I thought I did a nice job all to code, but now I'm reading some petty details that I need to have a handle tie or a spdt to kill the yoke entirely? What's the point of having tab breaks on the neutral side for such an application?
Given how short the circuit run is can't we just look the otherway at such code detail? :/
