Can a split bolt connector be used on grounding electrode conductors and similar conductors (such as lighting arrestors when bonded to a ground ring) when bonding or connecting conductors? This would be a situation other than a splice or a tap under NEC 250.64(C) and (D).
When you look at 250.64 (C) is regulates "splicing" and allows only irreversible compression fittings. 250.64 (D) discusses "taps" and allows any "listed" connector.
It is if it has DB on it.A ground rod clamp is listed as suitable for direct burial. Is a split bolt? Im thinking not.....just clarifing.....![]()
So what's D8? is that typically silicone bronze or something. I've just been around ole copper and combo CU/AL plated kearneys.......It is if it has DB on it.![]()
DB. Durect Burial.
db or DB = Direct Burial
FYI: a good link
http://www.iaei.org/magazine/departments/ulquestion_html/07culq1.html
The OP mentioned the GEC - grounding electrode conductor.
Generally, a split bolt is listed as suitable for grounding purposes, hence it meets the requirements of 250.8.
Generally, a split bolt is not listed for direct burial.
So, for other than direct burial a split bolt is permissible.
Sorry guys, I didnt have my glasses on, If Id seen DB instead of D8, I would have picked up on that.......Setting here drinking coffee and doing office work...![]()
Isn't D8 a Caterpillar?. . . it did look a bit like D8
HA HA, Ive always wanted to operate one of those, But I dont think my back and my guts would take it.............![]()
