Split hvac system
Jrh62972
Phoenixville
I have to wire a 208 v single phase split system unit. I need to feed the condenser with 2 hots and a ground. Then from the condenser into the unit on the inside they are calling for 3 #12 and a#12 ground. The third wire supposingly communicates through voltage. I need to know if I mount a disconnect by this unit or a toggle switch and where does this third wire go
