220209-0654 EST
See
A split-phase induction motor is a type of single-phase induction motor in which the stator is provided with a starting or auxiliary winding (S) and a main or running winding (M). The starting winding is displaced by 90 from the main winding as shown in the figure.
www.tutorialspoint.com
for a discussion of how a split phase motor works.
A true pure single phase induction motor has an oscillating magnetic field in only one direction in space. This goes from zero to a maximum positive value, then reverses, and goes back to zero, and reverses to a maximum in the opposite direction ( negative ), and then back to zero. This kind of magnetic field oscillation will not start a motor rotating. You could put a pulley on the motor and wrap a rope around the pulley and use this to manually start a pure single phase motor.
However, that is not a practical method. Thus, if instead you can create a magnetic field that rotates in space, then you can have an auto start means. There are various ways to do this.
The so called "split phase motor" is one way.
By adding a second winding to the motor, positioning it 90 degrees from the main winding, and feeding a current shifted in phase from the main winding you can create a somewhat rotating magnetic field that will start the motor. This start winding is dropped out when the motor reaches a sufficient speed.
Once you have a true single phase motor up to near full speed, then the single phase pulsating input can keep the motor running near synchronous speed. This is because off the inertia of the system. It operates much like a swing where you pulse energy into th swing in sync with the swing motion.
One bad characteristic of a single phase motor is that puts torque pulses into the load.
Not mentioned in the referenced discussion is that direction of rotation is determined by the relative phasing of the start and run windings.
