Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
When considering as the NEC describes “lighting and general use receptacle” branch circuits, I was wandering if it is common practice to share room lighting with receptacle lighting
I can see this going both ways. A contractor may want to save money by sharing ceiling switched lights with wall 20i amper cercuit power on the same branch circuit supply. However, due to tap rules, this arrangement would require the lighting circuit to have larger conductors such as NM 12-2 Romex switch legs and conductors instead of smaller 14-2 NM romex but will illuminate extra “home runs”
The other option is to keep lighting and receptacle on separate circuits such as receptacles on 20i NM 12-2 circuits and lighting on its own circuit using smaller NM 14-2 but the lighting circuits will require their own feeder run and likely will not come close to loading up a 15 ampere circuit to 12 amperes unless all lighting were done on one 15i branch circuit with LEDs at a fraction of an ampere each
Thoughts?
Thoughts?
