Conduit Sealing Fittings
With Drains
Chico Sealing Compound and
Fiber see pages 161–162
Cl. I, Div. 1 & 2, Groups B, C, D?
Cl. II, Div. 1, Groups E, F, G
Cl. II, Div. 2, Groups F, G
Cl. III
Explosionproof
Dust-Ignitionproof
Applications:
EYD drain and EZD drain and inspection
sealing fittings:
• Restrict the passage of gases, vapors or
flames from one portion of the electrical
installation to another at atmospheric
pressure and normal ambient
temperatures
• Limit explosions to the sealed-off
enclosure
• Prevent precompression or "pressure
piling" in conduit systems
Drain sealing fittings are installed in vertical
conduit runs and at low points in conduit
systems to prevent accumulation of
condensate above seal.
For sealing fitting requirements
see page 145.
Features:
EYD and EZD drain sealing fittings include:
• Drain to provide continuous, automatic
drainage of condensate
• Large openings with threaded closures
to provide easy access to conduit hubs
for making dams
• Integral bushings to protect conductor
insulation from damage
• Taper-tapped hubs to ensure ground
continuity
EZD drain and inspection sealing fittings
also include:
• Removable covers for periodic
inspection of seals
• Barrier for sealing compound easily
installed after dams are made and
before compound is poured.
Standard Materials:
• Bodies, and inspection or drain covers –
Feraloy? iron alloy and/or ductile iron
• Closure for drain – copper-free
aluminum or ductile iron
• Small closure plug – Feraloy iron alloy
and/or steel
• Drain – stainless steel
• Removable nipples – steel
Certifications and
Compliances:
• NEC/CEC:
EYD11-101, 116-1016
Class I, Division 1 & 2, Groups B, C, D
Class II, Division 1, Groups E, F, G
Class II, Division 2, Groups F, G
Class III
EYD1-10, 16-106,
EZD10-60, 111-611
Class I, Division 1 & 2, Groups C, D
Class II, Division 1, Groups F, G
Class III
• UL Standard: 886
• CSA Standard: C22.2
Ordering Information - EYD
1/2" – 1"
Female hub
1/2" – 1"
Male &
female hub
11/4" – 4"
Female hub
11/4" – 4"
Male &
female hub
Hub
Size
Female
Hub
Cat. #
Male &
Female
Hub
Cat. #
Female
Hub
Cat. #
Male &
Female
Hub
Cat. #
Approximate
Internal Volume
in Cubic Inches
1/2 EYD1* EYD16* EYD11 EYD116 1
3/4 EYD2* EYD26* EYD21 EYD216 2
1 EYD3* EYD36* EYD31 EYD316 33/4
11/4 EYD4* EYD46* EYD41 EYD416 8
11/2 EYD5* EYD56* EYD51 EYD516 103/4
2 EYD6* EYD66* EYD61 EYD616 20
21/2 EYD7* EYD76* EYD71 EYD716 35
3 EYD8* EYD86* EYD81 EYD816 57
31/2 EYD9* EYD96* EYD91 EYD916 75
4 EYD10* EYD106* EYD101 EYD1016 105
Dimensions
In Inches
EYD 1/2" – 1" EYD 11/4" – 4"
EYD Drain Seal
Size a b
Turning
Radius
1/2 39/32 11/4 15/8
3/4 311/16 11/2 129/32
1 45/16 23/16 23/8
11/4 51/16 23/16 127/32†
11/2 51/2 27/16 21/16†
2 61/4 3 25/16†
21/2 71/2 31/2 211/16†
3 81/2 41/4 35/16†
31/2 93/16 43/4 37/16‡
4 93/4 51/4 31/2†
†With cover removed.
*Available in copper-free aluminum – to order, add suffix SA to Cat. No.
Sealing Fittings are approved for use in hazardous locations only when Chico? X fiber and Chico A sealing compound or
Chico SpeedSeal are used to make the seal.
?See Certifications and Compliances for classification of each product.
6F
Standard Finishes:
• Feraloy iron alloy and ductile iron –
electrogalvanized and aluminum acrylic
paint
• Copper-free aluminum – natural
• Stainless steel – natural
• Steel – electrogalvanized
Options:
Description Suffix
Copper-free aluminum bodies,
nipples and enclosures SA
Size Ranges:
• EYD – 1/2" – 4"
• EZD – 1/2" – 2"
110.3(B) for one
