Had a General Contractor just call and ask if it’s allowable to spray foam a load center that’s installed in a wall separating a finished garage and residential living space.
I don’t know the physical properties of the product, but he said it would be applied about 1 1/2” thick on the back side and also encapsulate all the NM cable the same going into the load center.
My thought was that any penetration of the product into the load center would cause a code concern.
Probably not much help with heat dissipation either.
Thanks
Thanks
