I am starting a new industrial remodel job and on the exterior wall there is a fire protection drain valve that you turn manually. My question is how close to the valve can I get with a 2500 amp 480 volt 3 phase switch gear.
Sounds like it might be an inspection loop. If that's the case it's nothing to worry about. Fwiw I've never seen sprinkler system drains terminate anywhere other than outside.
