JDBrown
- California
- Electrical Engineer
I'm looking for a multiconductor cable (5 or so conductors, #18AWG) that can be run through an attic, down the outside of a wall, and then underground. As far as I can tell, that means it needs to be CL2, Direct Burial, Sunlight Resistant, and rated for Wet Locations. Unfortunately, I haven't been able to find one cable that meets all these requirements. Does it exist? If so, can you give me a link or manufacturer/model number?
For those who are interested in background information, I'm putting in an automatic sprinkler system (the irrigation kind, not the fire protection kind), and I want to make sure the right kind of cable gets used. The controller (which has a Class 2 power supply) will be inside the garage, and the plan is for the control cable to run up the wall, into the attic, through the attic to the opposite end of the house, down the outside of the exterior wall, into a trench, and underground to the sprinkler valves. The irrigation guys around here use the same cable for everything -- the type that is commonly found at home improvement stores -- and, while it is rated for direct burial, I can't find anything that leads me to believe it can be run in an attic or exposed on an exterior wall. I'd rather provide the cable myself and let them install it, than have them run that stuff through my attic.
So, is there a cable that fits the bill? What would you use?
