mikeames
- Gaithersburg MD
- Teacher - Master Electrician - 2017 NEC
Does anyone have a link to a schematic for the 8536 series motor starter. I looked on their site but it says the document was not found
heres where I went
http://www.squared.com/us/products/motor_control.nsf/unid/EC924FC4F4087F6C85256A1F005F9169/$file/nematech.htm
I have never had any control wiring problems before but this one is just not right and I want to confirm all of the connections.
The NO contacts are feed from a factory installed wire and I really want to use both sides of the NO contacts. Suggestions??? It feeds a 71/2 hp pool pump. The NO contacts will be part of the start circuit to hold the contacts in. Then the E stop will be in series with this circuit to drop it out. The usual motor start /stop circuit.
Thanks
heres where I went
Thanks
