- Bremerton, Washington
- Master Electrician
I have a security lighting system to control, consisting of 9 120V induction luminaires. I was going design and build a relay panel with HOA switch, lighting contactors, disconnect, etc, to control from a photocontrol and monitor operation via a PLC.
But Sq D makes a Powerlink G3 lighting control system, that has motor operated circuit breakers, factory assembled and tested. It uses a standard NF panelboard, and I can control from the PLC with a modbus protocol. The Powerlink would seem to be about the same cost as the fabricated panel.
Does any one have any experience with the Powerlink system? According to Sq D this is a system that is used by a lot of retailers.
This is for a critical facility that will eventually have security cameras and photobeam detectors.
