Sq. D QO retaining bracket
kitsr
Has anyone had to install the red retaining bracket on a qo breaker when used as a main breaker across the buss?
I could not figure out how to install this.
Any help would be appreciated.
tom baker
Bremerton, Washington
Master Electrician
Re: Sq. D QO retaining bracket
there is a small hole in the breaker mounting rail, the hex headed screw threads into the hole. Its easier if you remove the panel interior from the can. If I recall the there are two types of the brackets, pkmb and pk2mb
electricman2
North Carolina
Retired Electrical Contractor
Here is the pk2mb.
edit: left out pic :eek:
[ March 29, 2005, 09:30 PM: Message edited by: electricman2 ]
electricman2
North Carolina
Here is the pk2mb.
Tom is right, it is easier to install with the interior out. The little sketch that comes with it is a little vague but study it carefully and you will see how it goes.
