brantmacga
Señor Member
- Georgia
- Former Child
Had a project recently where the customer wanted to add programmable lighting controls on their building.
They had an NQ panelboard, so rather than installing lighting contactors, I used SqD Powerlink remote switching breakers as the cost in material was half what the contactors would've been, and the labor was exponentially lower.
The issue is that the breakers do not reliably switch off/on. Usually on each cycle, at least one breaker will not switch. The label on the power supply (as shown in pic below) says "non-continuous duty cycle, 2 seconds min recharge time....". I called square d before ordering all of this and they told me that continuous contact relays would be fine. I'm wondering though if that is part of my issue? I have programmable timers connected to 24vdc ice cube relays. SqD also recommended 3 breakers per power supply, and I have divided them as such.
Anyone have experience with these? Have you seen this problem?
We did multiple setups like this, and so far only the one that is giving me problems.
